what filter kit for blaster?
Old Oct 14, 2004 | 11:43 AM
DRoCk's Avatar
Default what filter kit for blaster?
I need to replace my air filter on my blaster...its completely stock and i would rather get something for more power than keep replacing the factory filter. What is a good filter to go with? I will probably remove the airbox lid, but i don't want to totally lose the airbox since i ride in pretty wet areas. I know i will need to rejet, so what kits come with jets? I know this question has probably been asked before, but a search didn't really help.
thanks
Old Oct 14, 2004 | 12:25 PM
CmyBackULose's Avatar
If you ride in dusty areas I would say a UNI filter and non-dusty areas a K&N with an outwear cover. I would just buy a main jet from the cycle shop and begin with 2 to 3 sizes bigger and do a plug chop to get it dialed in correctly.
Old Oct 14, 2004 | 12:54 PM
DRoCk's Avatar
I spend most of my time in a dusty environment. Are most of the filters about the same as far as power gains are concerned? I probably should expect a little more low end from the filter upgrade, correct?
Old Oct 14, 2004 | 02:37 PM
sAyIt_fmf's Avatar
I'm not sure you will notice any gain by just changing the filter itself. The weak link in the system is the airbox itself and how much air it will let to the filter.
If you were to open your airbox...and get a more free flowing filter. Then you will notice some gain....But it will be lean unless you rejet.
Old Oct 14, 2004 | 10:47 PM
Since you ride in dusty enviroment I would definitely say get a foam type filter like the UNI filter this filter IMHO would be the best filter with the airbox lid removed. You will need to rejet for the airbox removal as I stated in the previous post. I believe your stock main jet is probably a 230 so I would start with 260 but also get a 250 this should get you real close.
Old Oct 14, 2004 | 11:16 PM
skinny's Avatar
i would get a k@n they are awsome
Old Oct 14, 2004 | 11:37 PM
If you like dust in your motor.
Old Oct 15, 2004 | 09:51 AM
sAyIt_fmf's Avatar
Thats not true at all...I run a K&N in my banshee with no airbox lid w/ an outerwear... I have run this setup for years now.
I ride everywhere everyone else does with no filter or dust problems....
Just keep the filter oiled and the skin clean.
Old Oct 15, 2004 | 10:06 AM
potentpete's Avatar
Use the Uni, they are quit and easy to clean and will dry in no time when setting in the sun, where as the K&N will have to sit overnight after cleaning, plus you can buy 2 uni's for less than the cost of a K&N and always have one oil and ready to replace the dirty one with no down time waiting for a filter to dry.
Old Oct 15, 2004 | 06:03 PM
DRoCk's Avatar
I knew it was between the UNI and the K&N. I hope to get a pipe and silencer in the spring and I really just don't like the idea of replacing stock filters til then...too bad i will end up rejetting twice...oh well.
