CARB SETTING TOOL FOR RAPTOR.......NEED ONE!
Does anybody have a decent carb setting tool for the raptor....If so,where did you get it? and do you have a link to a website for it. Everybody knows that it's a real pain in the azz to do anything with the carbs on the raptor...esp main jet swapping.
I don't think you can swap mains without pulling the carbs. But Motion Pro makes a 110 degree (maybe its 115) angle necked screw driver that adjust the fuel screws while the bike is running.
edit: sorry its a 90 degree, I don't know where I got 110.[img]i/expressions/face-icon-small-blush.gif[/img] screw driver...scroll down a little
To adjust the AF screw on the stock carbs, I cut a small screwdriver. Hacked the handle down to a nub and cut the shaft to 1.5" with a thin flat tip. It worked fine if I waited until the engine was cool. If the engine was hot, I always burned my hand a little. You can't change main jets on the stock carbs while they are attached.
Originally posted by: RAPTORAZ
Sure you can. But it requires removal of the header pipe and the starter.
Originally posted by: UBETRUN You can't change main jets on the stock carbs while they are attached.
Originally posted by: garyc660R
By the time the change was done you could have taken the carbs off twice testing mains.
Originally posted by: deltadawg
DAAAAAAM, that thing is over 100 bucs. I guess I'll be getting athritis and cramps for a little while longer. Thanks anyway.
this one. Scroll down the page to the pilot adjusting tool. Works great for the air/fuel screw on the Raptor. $29 still a bit pricey but not as bad as the $109 model.
Mojave250A
Jul 11, 2015 10:38 AM
