12 or 13 tooth for my banshee
Old Nov 9, 2004 | 03:51 PM
latervikes's Avatar
Default 12 or 13 tooth for my banshee
Okay, it turns out my shee is ported for sand drags. The advice I keep getting to get more low end is to go with a smaller sprocket up front. How much difference will just dropping 1 tooth make? Since I have NO bottom end at all I am thinking of dropping down 2 teeth to the 12 tooth sprocket. I don't mind losing some on the top end as it is very rare I am wide out in 6th gear. Any input would be appreciated.
2001 Banshee
73HP
too many mods to list.
Old Nov 9, 2004 | 04:03 PM
Shav0's Avatar
One tooth will be plenty. You will gain alot of bottom end, but you will loose about 7mph on the top end. The problem with going to a 12 is that it shortens your gears too much. You will have alot of bottom end, but you will find that your 1st and 2nd gear dissapears and you will be in too high a gear all the time. My advice is, try the 13. Then if your still not happy drop another tooth. But I guarantee you'll like the 13. It dosn't seem like one tooth can make a difference, but it does.
Shav0
Old Nov 9, 2004 | 04:12 PM
latervikes's Avatar
Great! Thanks for the input...I will start with the 13 tooth.
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
