Raptor is pulling to the left????????
Old Nov 10, 2004 | 02:20 PM
Brutel1's Avatar
Default Raptor is pulling to the left????????
Thanks guys! I'll give it a go.
Old Nov 10, 2004 | 02:28 PM
omahapredator's Avatar
rear end could be swapping out too, if that don't work try the suspension!!
Old Nov 10, 2004 | 02:40 PM
QuadAddiction's Avatar
Did you ever flipped?? even the smallest flip??
It heppand to me twice... i flipped my ds in 2th and even first gear like a dumb kid.... both times 1 of m a-arms got a small bent which cause my quad pull hard on each side...
Old Nov 10, 2004 | 02:56 PM
maddog56's Avatar
He stated that it still pulls with the front end in the air, so front end and supsension issues should not be affecting him.
I had the same problem a few times. Once it was a low tire, once was bad carrier adjustment (which I think his is), and the last was an untrue swingarm.
Old Nov 10, 2004 | 02:59 PM
  #15
Brutel1's Avatar
Never!
Old Nov 10, 2004 | 03:10 PM
  #16
all i was saying is that if the rebound is too fast your rear end will swap and go in one direction....
Old Nov 10, 2004 | 03:17 PM
  #17
kaotik's Avatar
I have two BRAND NEW raptors and when you really get on it, they actually pull to the right very little. I know that mine is caused by the front end SLIGHTLY coming off the ground and the torque of the engine is pulling it to the right. I know that nothing is bent or messed up. If yours is pulling left though, you might want to check it out or it might just be because of torque as well. Im not sure, just thought Id let you know what mine are doing.
Old Nov 10, 2004 | 03:42 PM
  #18
Jibrille's Avatar
Also level ground might be a factor, I'm not trying to be an *** calling you dumb or anything, though my friend thought his quad was warped because his would travel left or right depending on the time he drove it. I found out it was the ground he was wheelieing on. :/ silly kid
Old Nov 10, 2004 | 04:10 PM
  #19
maddog56's Avatar
Most roads in our neck of the woods are crowned, so you will pull. And most driveways and trails are not level either.
Old Nov 10, 2004 | 04:16 PM
  #20
Brutel1's Avatar
Come on now. I know it has to be level gound.
