Raptor is pulling to the left????????
Old Nov 10, 2004 | 04:21 PM
  #21
maddog56's Avatar
Default Raptor is pulling to the left????????
Originally posted by: Brutel1
Come on now. I know it has to be level gound.
I know that, I was referring to others, like maybe kaotik. No offense, but 2 stock bikes with properly inflated tires and adjusted swingarms should not be pulling on level ground.
Old Nov 10, 2004 | 05:28 PM
  #22
1LeSSRaptor's Avatar
Originally posted by: 1LeSSRaptor
Make sure that the rear axle is tight on the bearings. If it comes loose even a little, on hard accel., the chain will pull on the axle and make it pull to the left.
This could be the two bolts sticking out of the rear of the swingarm carrier or also the large nut on the axle that keeps the axle tight on the bearings in the carrier is loose.
Old Nov 10, 2004 | 06:15 PM
  #23
MasterRaptor's Avatar
Check your left rear hub. If you don't keep the hub castle nuts torqued on the Raptor, the axle spline will strip. This would cause your problem.
This happened to two of my buddies Raptors.
Old Nov 10, 2004 | 06:17 PM
  #24
Brutel1's Avatar
No that you say this, i did find the left side loose. I just tightened it up. It has no play in it now.
Firefighter400
Oct 8, 2022 06:38 PM
brad wheeler
Jul 13, 2015 11:19 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
