Raptor is pulling to the left????????
Old Nov 10, 2004 | 01:38 PM
Brutel1's Avatar
Default Raptor is pulling to the left????????
I got a 2004 Raptor 660. On hard accell it pulls to the left. Any idea why? I check air pressure and they are the same L&R.
Old Nov 10, 2004 | 01:46 PM
omahapredator's Avatar
check your compression and/or rebound adjustment if equipped!!!
Old Nov 10, 2004 | 01:52 PM
maddog56's Avatar
Somehow I doubt your shocks have magically gone out of sync. I havent seen the stockers adjust on their own.
Check your tire pressure and front end alignment. You may have a bent tie rod, a low tire, or a tweaked steering stem or handle bar.
Old Nov 10, 2004 | 01:53 PM
Brutel1's Avatar
I don't understand. What commpression, rebound eqp.
Old Nov 10, 2004 | 01:55 PM
Brutel1's Avatar
When you hit the gas the front wheels are in the air. Something in the rear is pushing left. Tire psi is the same. 3.5 psi.
Old Nov 10, 2004 | 01:57 PM
1LeSSRaptor's Avatar
Make sure that the rear axle is tight on the bearings. If it comes loose even a little, on hard accel., the chain will pull on the axle and make it pull to the left.
Old Nov 10, 2004 | 02:02 PM
Brutel1's Avatar
That sounds like that could be it. Are you talking about the 2 bolts that run through the rear center section?
Old Nov 10, 2004 | 02:03 PM
maddog56's Avatar
Yes, thats what he's referring to.
You want to make sure that both bolts are exactly the same number of threads into the bearing carrier and that the lock nuts are tight too.
Old Nov 10, 2004 | 02:06 PM
Brutel1's Avatar
If they are not, than it will angle the rear axles correct? Making it go left.
Old Nov 10, 2004 | 02:14 PM
maddog56's Avatar
yes
