what is wrong with this
Because the transmission is still using the same gearing you started with. You need to reclutch if you want a top speed increase. You really need to reclutch anyway to take advantage of the power increases.
I bet if you change it to an 800cc you will still get the same results.
I hope you havent been busting your wallet to go faster with the bigger engine builds....?? Its real cheap to purchase some gears[img]i/expressions/face-icon-small-wink.gif[/img]
Go up one tooth in the front, or drop a couple in the back. Or you can change your tire size, either way you will gain top speed, but will loose on the bottom.
Originally posted by: NEWDUCK
its a grizz no outer gears. to change the top speed you have to either change tires or mess with your clutch.
geo
