Intake Kit question.
Old Nov 14, 2004 | 11:34 PM
PolishCowboyPL's Avatar
Default Intake Kit question.
This intake kit....
http://alba.buyol.com/Item/PD206.htm
Disregard the price, thats only to show you what I'm talking about.
It says you need to do drilling but its "easy".
Does anyone have this kit? Is it good, and what does it take to install it? Do you have to cut your airbox so it will fit those two holes for the filter?
And is this considered major modification to the air box, because I saw that the HMF pipe has a jetting setup and it says jetting different for airbox mods.
Thanks,
MIke.
Old Nov 15, 2004 | 02:28 AM
Swansonator's Avatar
If you dont have one of these you better order it know. The stock air filter has been known to allow dirt past it do to poor sealing. This is one of the first mods you should do. Just about everyone uses this. It is an easy install. You have to drill holes for the mounting screws and if I rember correctly I had to trim some tabs off the lid, which I dont use anymore anyway.
Old Nov 15, 2004 | 06:33 PM
camshaft9's Avatar
it is a very easy install you have to drill a few holes and cut some of the old filter holding tabs off but is a very nice set up and it is worth the money and the 15 minutes to put in. I used a hot knife to cut my tabs off workrd good
Old Nov 15, 2004 | 09:58 PM
There is this one and the Alba racing one, which is 30 bucks cheaper, as long as its a K&N filter is everyhting else the same?
Scooter's Shop
23
Oct 22, 2015 07:04 PM
bigred20653
Oct 2, 2015 10:05 AM
Sassinm1
Sep 30, 2015 04:23 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Bigtwin700
Sep 9, 2015 09:32 AM
