What does a 686 Raptor consist of?
Old Nov 18, 2004 | 11:35 PM
badazz660R's Avatar
Default What does a 686 Raptor consist of?
what all needs to be done to make it a 686, how big of bore, what parts, how much will it cost, etc. thank you
Matt
Old Nov 19, 2004 | 12:08 AM
Yamaha660R's Avatar
A 686 is a 102mm bore. All you have to do to say you have a 686 is bore the cylinder and get a 102mm piston. But usually you will want to get a cam, port work, carb's, rod and crank balence, aftermarket valve's and springs, and exhaust/filter.
The sky is the limit...and the price goes up with the faster you want to go....
Old Nov 19, 2004 | 01:32 AM
UBETRUN's Avatar
Ain't that the freakin truth! Unless you are insane *and* filthy rich, don't tell Bob Craycraft that you have to be the fastest:-)
Old Nov 19, 2004 | 01:45 AM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
And do it all at once!!!!!!!1 Its much cheaper in the long run. Although I do have a spare hmmmm
Old Nov 19, 2004 | 07:57 AM
ZimRaptor's Avatar
thats overkilling it...carb? valve springs? i wouldnt go that far...unless u got a lot of $$$$, rod and crank is manditory, ive heard a lot of problems with stock ones on big bores
Old Nov 19, 2004 | 01:42 PM
1BADRAPTOR's Avatar
I go big the first time like scholle said, the first small build will not be fast enough, and if it is then thank god because i built this thig 3 times and wanted to go faster everytime...
Old Nov 19, 2004 | 02:33 PM
Yamaha660R's Avatar
I've built mine 2 times....going on another couple upgrades this winter....and maybe a bigger bore in summer or next fall. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Nov 19, 2004 | 11:53 PM
duneittilludie's Avatar
badazz660r-As others have suggested it depends on how deep your pockets are but if i were you i would do it right the first time or you will probably regret it later.My first 686 consisted of only a 102 mm 11:1 piston/air filter/jetting and a pipe and header and although it was quite a bit faster than just a piped raptor it wasnt even close to what i have now.I now have porting/cams/valves/valve springs/lightened flywheel/102mm 12.5:1 piston/six six t air filter adaptor/oversized exhaust valves/carillo rod/and the LTE dual exhaust system.I listed all the above to suggest to you that the incredible amount of performance that i now get was worth the cost in my opinion and it even carries my 230 lbs to wins against some quads both two and four stroke that i never thought i would have a chance against in a drag race.The older i get (46) the more i realize that doing something right the first time is usually the best way to go in the long run even though initially the cost may seem scary.
Old Nov 20, 2004 | 12:46 AM
Yamaha660R's Avatar
You will spend a lot more money with a minor build and then going up...up...up and up. If you build it right, and get everything you want the first time...it will cost less then building it once. Then changing something....then changing something else. Just do it right if you want to build your quad, and you will be better off and won't spend nearly as much $$ in the long run.
Old Nov 20, 2004 | 02:39 AM
badazz660R's Avatar
thanks for the reply. When I get the money i think I am gonna go all out and do it right the first time, but first i need to get an 02 trans set up and a pipe. but mostly i need some money.
