RE: blaster ran like sh!t today!!!
Old Nov 19, 2004 | 11:36 PM
Rem's Avatar
Rem
Default RE: blaster ran like **** today!!!
ya know what? fu(k you all! i know theres plenty of you people out there who can help me, but they dont want to cuz it requires a little reading, but hey most of the people on this forum probably didnt even go to college. thanks for nothing
Old Nov 20, 2004 | 01:10 AM
Rem's Avatar
Rem
you guys are ga y!!!!!!!!!!!!!!!!
Old Nov 20, 2004 | 02:22 AM
RaptorRookie's Avatar
Ok, geez calm down. You say your fouling plugs, so the first question I would ask is what mixture are you running? I haven't worked on a Blaster in a while, but with the mods you listed I would say jetting up maybe 2 or 3 sizes from stock. You have a slip on, but those stock blaster pipes are fairly restrictive. What screws did you bro mess with, air/fuel? That could really mess things up depending on which way he went with them. Also, the dying when letting off the throttle could be the safety switch in your throttle housing. If you take off the throttle cover on your handle bars, you will see a few parts. Push the thumb throttle a bit, you will see that there is one part that the cable connects to that pushes another metal lever. If the cable returns but the other metal piece doesn't, this will kill the engine. It is a safety thing so the throttle doesn't get stuck open. Take out the three screws and see if everything is moving smoothly. If it is not smooth, clean everything up, and make sure to clean your throttle cable. Try that and see what happens. Hope it helps.
-Brandon
Old Nov 20, 2004 | 02:30 AM
raptor8's Avatar
you might have better results when you work on yer people skills. go back and look at how you treated people and see if you would answer this character. This aint burger king - you CANT have it your way.
if it was a dramatic change, then you have an engine problem.
fuel, air, spark, thats all there is to it, and compression.
and plug can look good and be worthless.
flooding is common, esp in cold weather.
good fuel? not out of the lawnmower right?
you should at least get a POP if you have fuel, air, spark and compression.
choke off, throttle wide open, kick it as if its flooded.
pull the plug and your thumb over the plug hole, roll it over.. compression?
keep trying, it is something simple hopefully.
please pull ahead.
Old Nov 20, 2004 | 02:59 AM
  #15
YFZ660R's Avatar
To ATV Thieves: "Hope you guys flip and die douches!"
I was about to help but nah, you don't talk to people that way, specially when you asking for help.
FUN RIDING!!
Old Nov 20, 2004 | 10:07 AM
  #16
86LT250RFatty's Avatar
yea really.
Old Nov 20, 2004 | 12:32 PM
  #17
Rem's Avatar
Rem
w/e i know there was plenty of people on here that couldve helped me, but they were too lazy to read my posts
i dont care what you bit(hes say, gotohell!
Old Nov 20, 2004 | 01:23 PM
  #18
Shav0's Avatar
Dude are you retarded?
No one is going to want to have anything to do with you if you treat them like that, I know I sure don't.
Old Nov 20, 2004 | 02:15 PM
  #19
Rem's Avatar
Rem
cant you understand my frustration.
Old Nov 20, 2004 | 02:25 PM
  #20
Shav0's Avatar
..no
