hotcams for the raptor 350
Old Nov 23, 2004 | 03:43 PM
new350raptor's Avatar
Default hotcams for the raptor 350
has anyone had the hotcams camshaft installed on their 350?...i want to buy it but i wanted to know if it's worth the 150 bucks beforehand...i want more lowend torque and i want to know if this is the right direction to go in...
Old Nov 23, 2004 | 06:25 PM
86LT250RFatty's Avatar
Hotcams generally give you more mid-high RPM power, the low stays the same.
Old Nov 23, 2004 | 11:04 PM
todster's Avatar
puting a web cam in the wolv next week same engine so i may be able to give some input then
Old Nov 24, 2004 | 01:16 AM
nice keep me informed
how hard is the install on that?...
Old Nov 24, 2004 | 03:44 PM
SpinCycle's Avatar
I put a megacycle cam in my girfriends warrior last year, with a wiseco piston, yoshi pipe and an open k&n filter it makes a great deal more power. The cam is very easy to install and could be put in just by removing the left side cover on the head, removing the cam chain gear and backing off the valve adjusters. I don't recomend doing this without changing the valve springs. The factory springs are very poor and you will not be able to gain the extra rpms on top with the factory springs, they will float. Order a new inner cam bearing, you will not be able to get the factory one off without damaging it and they are only like ~$14.
Old Nov 24, 2004 | 06:09 PM
todster's Avatar
spin cycle whats the deal with the cam bearing i hear it comes right off then i hear it extreamly difficult. i asked web cams they said its not pressed on.??????????i guess ill find out next week
Old Jan 14, 2005 | 02:08 AM
VelociRaptor350's Avatar
im putting a hotcam in my rappy next week when it shows up ill let you know when its in.
Old Jan 14, 2005 | 11:51 AM
toy4rox's Avatar
i just did one in my warrior and the bearing was not that hard to remove. i just put a bearing puller on it and it came off easy.any smoll puller could do it. i am running my stock valve springs and can't tell any problum with floteing. how would you know if it was floteing ?
i can't tell if it did that much to the HP of the bike becouse i did a lot of stuff at the same time.but it is alot better now
Old Jan 14, 2005 | 03:54 PM
Boxhead's Avatar
You'll know if you float the valves, it will suddenly make a gargle or very strange sound when you hit full throttle and almost top your rpms. As for cams I would rather get the megacycle that was mentioned or the web race cam. As for the bearing I've only seen a 400EX rebuilt, and the bearing was pretty tight on the cam. To get a new bearing on the new cam you'll probably need a socket that's rim lies right on the rim of the bearing, and a rubber mallet to slowly tap it on there. I'd worry about dealing with the cam chain more than the bearing, that will definately slow you down if you have any trouble.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
