2005 Raptor Clutch...ugh
Old Dec 3, 2004 | 09:13 PM
nike6g's Avatar
Default 2005 Raptor Clutch...ugh
I just took delivery of a brand spankin new 2005 Raptor 660R. I read through the manual like a good little owner...started it up. Well I pulled the clutch in, dropped it in 1st (like the manual says) and it jumped on me. The clutch didn't work. If I put it in 1st and hit the start, it will creep forward. Has anyone ran into this problem, or is it a manufacture defect? Please help! [img]i/expressions/face-icon-small-sad.gif[/img]
Old Dec 3, 2004 | 09:27 PM
ZillaRider87's Avatar
adjust your clutch, on the left side of the engine, rotate the bolt a few turns. i forgot which way to rotate it, so just try both ways. thats all thats wrong
Old Dec 3, 2004 | 09:35 PM
nike6g's Avatar
[img]i/expressions/face-icon-small-sad.gif[/img] I have tried to adjust the clutch cable both at the bars and at the motor...either i'm doing something wrong, or there is a problem. Anyone else have any problems with this or heard of it.....any other ideas?
Old Dec 3, 2004 | 10:13 PM
rutelis's Avatar
mine does that too sumtimes...u suppose to start in nutral becouse of the oneways starter...u probly can jus ajust the cable..if not jus hold the brake when u shift into 1st and suck it up and ride
Old Dec 3, 2004 | 10:27 PM
DelawareRaptor's Avatar
Don't worry about it it's normal due to two things. 1. On a cold start the oil bath clutch disc are cold. 2. No brake in yet.
Old Dec 3, 2004 | 10:54 PM
HughJazz's Avatar
Mine does that when you 1st start it and put in in gear.
Old Dec 4, 2004 | 03:08 AM
blindside350's Avatar
Yup, our YFZ occasionally jumps when the clutch is pulled. Thinking about it only after its been sitting for awhile...but not every time..Wierd
Old Dec 4, 2004 | 03:20 AM
XxDumontRaptorxX's Avatar
Sounds to me like your clutch is engaged still while you have it pulled in. To correct this you need to move the 2 nuts on the cable that leeds to the clutch thats on the right side of the engine case. I believe you would move the nuts towards the back of the quad.
Old Dec 4, 2004 | 03:21 AM
Since you just bought it, you could also take it to the dealer and tell them your problem, they will more than likely fix it for free.
Old Dec 5, 2004 | 02:00 AM
CTracingraptor's Avatar
the clutch is engaging because your oil is cold, and your adjustment is slightly off, if you have a warranty i would just take it to your dealer, otherwise. my raptor does it sometimes no big deal, once it warms up no problem, start it with clutch pulled in and in 1st gear.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
01ssls1
Sep 22, 2015 06:50 AM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
