raptor smoking at warm up
Old Dec 13, 2004 | 10:52 PM
BUDXXX's Avatar
Default raptor smoking at warm up
SO I changed the oil and adjusted the valves, now during warm up the thing smokes like hell.
COuld I have screwed up a valve guide torguing on the valve adjustment nut????
Anybody got any Ideas???
Old Dec 13, 2004 | 11:01 PM
86LT250RFatty's Avatar
sounds like somethig broke and oil is leeking into the cylinder.
Old Dec 13, 2004 | 11:26 PM
Voodoothenoob's Avatar
where is the smoke coming from?
Old Dec 14, 2004 | 01:08 AM
BUDXXX's Avatar
during warm up smoke coming from pipe.
Could be valve guide??? I was really carefull adjusting valves.....but I did feel one valve or rocker sort of shift during tightening of nut.....It could be I wiped the valve guide but...it did not seem like I put that much stress on it....
I'll check it tommorrow after motor gets cold and I recheck the valves....if it still smokes......I might have to yank the head.....bummer,...only 100 hours on it.....
Old Dec 14, 2004 | 12:36 PM
CTATV's Avatar
My buddy's warrior smokes a bit during cold startup and for like the first 5 or 10 seconds but then it burns off and doesnt smoke anymore. does yours keep smoking?
Old Dec 14, 2004 | 12:43 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
what color smoke?
does it only do it with the choke on?
Old Dec 14, 2004 | 01:20 PM
BUDXXX's Avatar
blue smoke with or without choke for about two minutes..
Old Dec 14, 2004 | 04:21 PM
BUDXXX's Avatar
Well I readjusted the valves, I had two intake and one exhaust, that were only slightly loose, and changed oil again to fix a leak on the pipe from oil tank to engine..... and when I lit it off it had only a few seconds of blue smoke with choke off then it pretty much was gone after one minute...so I guess it's not as bad as I thought it was the other night...
I will continue to keep and eye on it, but what I SAW today I don't think will a problem.....
The thing that I felt "moved" inside the tappet cover was probably just the rocker shifting back and forth on it's shaft.....I could not have applied any torgue or pressure on the actrual valve....
bvolks
Sep 13, 2015 12:57 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
