Changing oil on rappy?
Old Dec 19, 2004 | 03:48 PM
86LT250RFatty's Avatar
Default Changing oil on rappy?
hey all. Is the oil tank in front of the motor the only place to fill up oil? I dont know how much my Tranny is filled with oil... on my oil cooler, the dipstick is about 2inch past the full mark.. .please help me out, first 4-stroke. thanks!
Old Dec 19, 2004 | 03:53 PM
Fahq's Avatar
That is the only place to fill the oil. The motor and tranny share oil so, don't worry about the level in the tranny. It will fill to the appropriate level. Thanks, Matt
Old Dec 19, 2004 | 03:56 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
you have to drain the oil tank,,,and the plug under the shifter on the bottom of the case
change the filter
replace plugs (carefully tighten the oil tank plug,,,some people have had trouble with the bottom cracking)
fill the tank till its full,,,,and start the motor to let it cycle thru the motor
cycle and add oil till the dipstick reads full (about 2 quarts)(checking the oil after the motor has been run)
I like to check the screw in the camshaft plug on the right side of the motor when I am finished to be sure that oil is circulating in the topend. (loosen the 8mm hex screw until oil leaks out (about 1/2 turn),,,,if it does your good)
Old Dec 19, 2004 | 03:58 PM
Bigdaddy660R's Avatar
I'm Short and Very Ugly.....
Here's a Raptor factory manual, browse thru it, i'm sure u'll find all the answers your looking for.........
Old Dec 19, 2004 | 07:10 PM
Thanks for all the repleys its been very helpfull. one last thing, what weight oil are you putting in your rappy's? its about 20 Degrees here if it makes a difference.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
