Best Swing-arm Skid plate for a Raptor?
Old Dec 20, 2004 | 03:24 PM
MasterRaptor's Avatar
Default Best Swing-arm Skid plate for a Raptor?
I just trashed my 3 rd skid plate on my Raptor. I started with an AC Racing .190. It lasted about 3 rides. Then I went to an Armidillo .25 thk. It lasted about 10 rides. I just trashed the PRM .25" yesterday. It lasted about 15 rides. They get bent beyond all repair. They crack when you straiten them.
Is there a skid plate out there that will hold up in Arizona?? Steel maybe?
Old Dec 20, 2004 | 03:37 PM
30Bones's Avatar
What are you constantly hitting to do that much damage? What size rear tires as well?
Unsure on what I have other than it's 0.25 thick and it has been hit hard a lot and never bent much other than deep gouges. I also took a hole saw to it to let the dirt/debris fall out at the rear shock area.
Now the belly skid plate is another story, mine is pretty hammered and I want a thicker one.
Old Dec 20, 2004 | 03:45 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
i agree with 30bones,,,,,,are you running 22" rears yet?
Don't use steel. The swingarm is aluminum,,,,,steel would actually be too rigid for an aluminum swingarm,,,,risk cracking the swingarm imo.
I have gone thru 3 skidplates on the raptor so far as well.
Old Dec 20, 2004 | 03:49 PM
It's rocky terrain here in the desert and I haul ***. I am running 20" rear tires. The skid plate is formed around the sprocket and brake disk from rock impacts. It's nasty.
I try to avoid them as much as possible.
I am running the stock belly pan. Don't have much of a problem there.
Old Dec 20, 2004 | 03:51 PM
Bing's Avatar
Super Quad Patrol
I here ya on the rock problems. We used to ride at a place in NC that was heck on skidplates.
22" rears and 23" fronts and you will hit the rocks about 60% less at least.
Old Dec 20, 2004 | 03:52 PM
Bing's Avatar
Super Quad Patrol
you may want to gear it down a little to compensate for the larger tire
Old Dec 20, 2004 | 04:43 PM
Actually, I am already geared down. I was thinking it was too much for the desert, I am always rapped out in 5th gear. 22" may just do the trick.
I am already running 23" in the front which is great on rocks. But I am going down to 22" because it rolls on the sidewalls in hard turns. Gives it a squishy, unpredictabe feeling.
Thanks!
Old Dec 20, 2004 | 04:57 PM
30Bones's Avatar
Didn't see you were in AZ.....LOTS of rocks out there to smack.
Old Dec 20, 2004 | 05:14 PM
86LT250RFatty's Avatar
Get the Tusk swing arm guard.
Old Dec 21, 2004 | 05:26 PM
Anyone ever try shock mounting their Skid plate?
