Banshee Break-in
Old Dec 24, 2004 | 03:34 AM
bluebansh's Avatar
Default Banshee Break-in
Ok, the Bansh is comin apart this weekend for a rebuild, how would u guys break a rebuilt banshee in. Ive broke in 3 new 4strokes, and ill be honest with ya, ive been taught "break then in how your gonna ride them" so when i broke them in the ran the sh** outa them, and they all ran strong, But i dunno if it would be the same deal on that 2stroke??
Old Dec 24, 2004 | 04:27 AM
VelociRaptor350's Avatar
same thing
Old Dec 24, 2004 | 04:37 AM
pendejo's Avatar
I took the following from sportquad.com
ATV OnLine Tech Sheet
by Colin Bylund, Editor ATV OnLine
Two Stroke Engine Break In
After engine has been installed and all fluids replenished (coolant/water, gear oil etc) you must then break the engine in properly. Improper break in results in lower reliability and possible engine seizures.
Use the gas and oil mixture ratio that you intend to run after the break in. Check all fluid levels periodically during the break in. Check the carb jetting periodically during the break in.
Part 1
Idle: Start engine and let idle with a fan blowing on the radiator to help it cool properly. Let idle for 15 minutes.
Cool Down: Shut engine off and let engine cool for a minimum of 30 minutes.
Idle: Repeat first step.
Cool Down: Repeat second step.
Part 2
Note: Be careful not to put unnecessary strain on the motor during the break in. Do not climb large hills or go through deep mud. If possible use a mild treaded tire. If you are on the sand do not use sand paddles.
Ride: Ride for 15 minutes varying your RPM not to exceed 50% of normal riding pace.
Cool Down: Shut engine off and let cool for a minimum of 30 minutes.
Ride: Ride for 15 minutes varying your RPM not to exceed 60% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 70% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 80% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 90% of normal riding pace.
Ride: Ride for 15 minutes varying your RPM not to exceed 100% of normal riding pace.
References: Duncan Racing Tech Sheet
I followed this, except while idling I "blipped" the throttle every 30-45 seconds to speed up the H2O impeller. An idling motor will not sufficiently supply coolant to the motor, which could cause overheating and you do not want that, especially during break-in.
Kaleb_00
Jun 1, 2016 09:15 AM
donintennessee
Aug 19, 2015 02:22 PM
greek271
Aug 8, 2015 08:16 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
