Raptor-Rattle in top end
Old Dec 31, 2004 | 02:42 PM
AustinONeal's Avatar
Default Raptor-Rattle in top end
i just got a new gyt-r clutch basket, pressure plate and the clutches installed in my raptor and when you start it it sounds like theres a little vibration in the cylinter, like if there was a wore out chain roller in the topend or maybe in the valve cover i really dont know what it is and it is making me worry. i really dont want to gernade the thing so i would apreciate some help. Maybe the cam tenisoner isnt tightening the cam chain, i dunno, also before i have the clutch installed i always had hell with the clutch slipping and afer i installed the clutch system i out some mystic JT8 30wt. and i dont really think that might matter but i thought it was worth mentioning. thanks for all the help
Old Dec 31, 2004 | 02:55 PM
warrior68man's Avatar
maybe the timing chain is gettin to loose.
Or you just need a valve adjustment
Old Dec 31, 2004 | 05:37 PM
DollarBillz's Avatar
yep i would check the valve's first
Old Dec 31, 2004 | 05:52 PM
well the valves have always had a little cladder from the cam but its more in the cylinder after listening to it a little closer more like the piston vibrating any thoughts?
Old Jan 1, 2005 | 04:51 PM
anyone else
