Raptor just clicks after hotcam install.
Old Jan 1, 2005 | 09:53 AM
witti's Avatar
Default Raptor just clicks after hotcam install.
I helped my friend install a stage 1 hotcam last night. Now when he starts it some of the time it clicks (like the battery is dead), and others it fires up llike it should. Never had this before the install. Also, It seems to run fine.
I did a search, I see a lot about the decompression pin. Would it run normal if this was in wrong?
Old Jan 1, 2005 | 11:52 AM
Vinson581's Avatar
yea my vinson does the same thing, the piston is at the top of the compression stroke, and has to much compression to start effectively by the started, get the engine to bdc, and then do it it will fire ever time. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 1, 2005 | 12:39 PM
86LT250RFatty's Avatar
where is the clicking noise coming from? Maybee the battery is just weak and cant turn the engine over at TDC
Old Jan 1, 2005 | 04:21 PM
witti's Avatar
It sounds like the starter. Just like a vehicle when it has a dead battery. did not do this before the cam install.
Old Jan 1, 2005 | 11:30 PM
UBETRUN's Avatar
I saw your post on the other forum. When you put the decompression mechanism back on the end of the cam, are you sure the little pins were inside the grooves on the weights? If you pull open the weights, the inner ring should turn freely.
Old Jan 2, 2005 | 05:01 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
UBETRUN is spot on....
You need to be sure that the pins are alligned properly with the conterweights.
I just had this very problem after my one-way went out and locked the bottom end at about 40.
your engine is not decompressing when you try and start it......,,,,and if it does start,,,,,you should hear a clack, clack, clack which would be the pin slapping the rocker as the engine revs
you will eventually cook your starter if you keep trying to fire it
its a simple fix[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 2, 2005 | 10:26 AM
witti's Avatar
Yes I pulled the weights out to line the groves up.
Are you talking about the shaft that the plunger rides on?
Old Jan 2, 2005 | 04:32 PM
Bing's Avatar
Super Quad Patrol
the shaft rides in the center of the cam,,,,and controls the decompression pin
Old Jan 2, 2005 | 04:35 PM
Bing's Avatar
Super Quad Patrol
here
the 2 little pins on the end of part #5 have to be alligned properly with parts #7
Old Jan 2, 2005 | 07:33 PM
witti's Avatar
I tore it apart today, and evrything is correct. It is also starting good now(dont know). The valves/rockers seem to make quite a bit of noise. There all at hotcams spec.
