727 not starting
Old Jan 1, 2005 | 03:47 PM
slowerthenyours's Avatar
Default 727 not starting
I can not get my 727 to start i have put in a new starter, battery, solenoid, and a L&A one way gear does anyone have any suggestions? It sounds like it is dragging when trying to start it.
Old Jan 1, 2005 | 04:01 PM
Shav0's Avatar
Have you checked for spark, to see if it's reaching the plug?
Old Jan 1, 2005 | 08:28 PM
86LT250RFatty's Avatar
try putting gas into the spark plug hole, or spray starting fluid on the airfilter, it might just be a tight fit from all the new parts.
Old Jan 2, 2005 | 03:52 AM
madracing's Avatar
check all gears from starter to ony way gear had same problem bearing was out on the starter gear put it in a bind
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
