oil change ?s
Old Jan 3, 2005 | 03:17 PM
saaben's Avatar
Default oil change ?s
tried posting under yamaha but no responces. if anyone could just reply real quick i would appreciate the help. I have a 1995 kodiak 400. tried to change oil and ran into some ?s. What size is the drain plug. leaking a little bit out of oil filter housing any tricks ? owners manual says to check oil galley bolt is to be loosened till oil seeps out. cannot get oil to seep out. any kodiak oil change guys with experience i would really appreciate it thanks.
Old Jan 3, 2005 | 06:08 PM
Raptorboy4life's Avatar
I've never changed oil in a Kodiac but i know that your filter might be leaking because the o-ring thats on it might not be moist?.. i usually and you should usually put a little oil in the filter before putting it on and put oil on your finger then rub it onto the o-ring to moisten it with oil!!!! make sure everything is dirt free, and sand-grain clean!!!!!!!
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
