Timberwolf Help
Old Jan 6, 2005 | 07:55 PM
Terri's Avatar
Default Timberwolf Help
Hi,everyone my name is Terri.I have a problem.I have a 1995 Yamaha ,250 Timberwolf.When I let the 4-wheeler idle it makes a coughing sound and eventually dies.What could cause this problem?
Old Jan 6, 2005 | 07:59 PM
Wolverine2003's Avatar
Dirty carb, partially plugged low speed jet, idle not set high enough. Does it run okay once it's above idle speed?
Old Jan 6, 2005 | 08:25 PM
Terri's Avatar
It runs okay if the choke is halfway on.Coughing occurs when the choke is off and I can only keep it running if I press the accelarater.
Old Jan 6, 2005 | 10:06 PM
Sounds like it's time to pull the carb and give it a good cleaning.
Old Jan 6, 2005 | 10:44 PM
Terri's Avatar
Thank you for the help.I have cleaned it once ,recently.I am going to ckeck the float adjustment.
Old Jan 6, 2005 | 11:25 PM
I think that carb has a spring loaded tip for the float valve. You should take a look at that to be sure it's moving freely.
When I got my Warrior last month it was running pretty lousy from sitting with stale gas. I drained the gas and it still wasn't running well. When I pulled the carb off and checked it the tip was stuck on the valve. I sprayed it and got it moving again, put the carb back together and it fired up and has been running fine since. I did check the float height on it and it was right in the middle of the specs.
Like you said, it's a good thing to check with it running like you described.
I had a Timberwolf back in '96. With a set of Mud Machines on the rear it went about anywhere the 4x4's did, and had a lot better splash protection than the Wolverine!
Hope you get it figured out, sounds like you're on the right track.
Old Jan 7, 2005 | 12:09 AM
Terri's Avatar
Thank you.I will check it tomorrow.Thanks a bunch!
Old Jan 7, 2005 | 12:21 AM
YFZ450kid's Avatar
check your airfilter too, i used to have a twolf and it ran really really bad when the airfilter was a bit dirty...
Old Jan 7, 2005 | 12:50 AM
2FAST4URASS's Avatar
i had a 96 that started doing the same thing i moved the clip up 3 on the jet and it cleared up give it a try.
Old Jan 10, 2005 | 10:02 PM
Terri's Avatar
Hey you guys ,I have checked everything and nothing worked.I cleaned the carb.,I checked the jets,and the float.I have even checked the filter.This Timberwolf is still coughing and dieing !!!!!!Do you guys have any more suggestions?Please help,please................
