What tires are right 4 me...
Old Jan 8, 2005 | 11:26 PM
BaD04WarrioR's Avatar
Default What tires are right 4 me...
I wanna throw some tires on my stock rims. My rear stocks have like 2-3 plugs in each tire. I ride mostly trail and through fields and what not. Ill probably leave my fronts alone unless prompted otherwise. Anyways stock is 22-7-10front and 22-10-9rear. The reason for the new tires is that the tires I have now are awesome but I want something a little lighter. They are 6ply. So anyways what brand and what size. I have +2 a-arms and +2-+4 rear axel coming in feb. And Im ordering works shocks all around if that will help at all. And 12t front sprocket
Old Jan 8, 2005 | 11:49 PM
Yamaha660R's Avatar
Personally I would gear up a tooth or two and put some 20's on the back. Something like a Razr or Holeshot.
Old Jan 9, 2005 | 12:13 AM
caliraptor's Avatar
holeshots, cant go wrong with them
Old Jan 9, 2005 | 12:21 AM
so 20 inch holeshots in the back. keep front the same. And which holeshots... xc or whatever the others are. should I go with 20-11-9 or does it have to be the same as stock which is 10(22-10-9) Tire width Im guessing
Old Jan 9, 2005 | 12:22 AM
86LT250RFatty's Avatar
20X11-9 HoleShot XCR's
Old Jan 9, 2005 | 12:51 AM
KVRMUDDRUNNER's Avatar
ITP all the way. I love them holeshots myself. I have never gotten a hole in my tires yet and I ride hard and on a ton of different surfaces
Old Jan 9, 2005 | 01:10 AM
So leavin the stock fronts are ok. the 22's
Old Jan 9, 2005 | 04:57 AM
Carmelo15's Avatar
if your going to get a 20 inch back tire you probably should get a smaller front tire accordingly. personally id go with the 20-11-9 kenda klaw XCR or the Maxxis razr
Old Jan 9, 2005 | 05:02 AM
Carmelo15's Avatar
the first number is the tire diamter, the second number is width and the third and most important is the rim size. as long as you get a 9 inch tire you will be fine. but make sure you have the clearnce if you want to get anthing bigger than a 22-11-9
Old Jan 9, 2005 | 09:41 AM
Banshee392's Avatar
Id go with the 20 inch rear holeshot XCR's and 21 inch Holeshot Tires for the front.
