Wheelies
Old Jan 10, 2005 | 09:56 PM
JoshyWashy's Avatar
Default Wheelies
i want to know what are the best mods that i could put on my stock yamaha wolverine to make it be able to wheelie easy...today i was out riding and the only way i could get it to wheelie was when i went up this 3 foot incline...i know there has to be some mods that will get my wolverine to wheelie easy...
Old Jan 10, 2005 | 10:00 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default Wheelies
maybe practice practice PRACTICE [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 10, 2005 | 10:57 PM
WheelieKing's Avatar
Default Wheelies
A Good slip on pipe, K&N filter, and rejet will give you the extra bottom end pull and help pull the front end up much better. Good luck. I don't know much about the availability of Wolverine pipes but I would suggest White Bros E-series. Also I think that the Wolverine uses that same old airbox design So I would get a Pro Flow kit.
Old Jan 10, 2005 | 11:09 PM
SpDdEmOn's Avatar
Default Wheelies
yeah wheelie king is right. Also running a little higher compression with an overbore, if you are willing to do a little bit of simple engine work would help greatly. Also look into racing airbox designs and torque valves (torque stuffer). Depending on your budget, its really hard to tell you what you should put on it.
Old Jan 11, 2005 | 12:25 AM
rutelis's Avatar
Default Wheelies
its gonna be hard to make it wheelie better since its awd....jus practice
Old Jan 11, 2005 | 07:13 AM
Redrizza's Avatar
Default Wheelies
It's all practice... Has nothing to do with power, and wheelies are a slow speed thing usually (will be on that quad) and a high compression piston would be your enemy by adding lots of heat.... So, that's the last thing you want to change. I wheelie my heavy *** foreman with the added weight of a winch in the front..... I've wheelied my buddies Wolverine (stock) and it is real easy compared to most 4x4's..... So, again, just practice on grass so when you stand it up on the rack and fall off you or the quad don't get hurt.
Old Jan 11, 2005 | 07:48 AM
D3athShad0w's Avatar
Default Wheelies
if you really cant wheelie by pulling up hard and gunning the throttle just give her gas and drop the clutch that **** will pop up >_<!
Old Jan 11, 2005 | 07:51 AM
VelociRaptor350's Avatar
Default Wheelies
damn d3ath, your up early, and i totally agree, just gas it, and if that dosn't work pop the clutch
Old Jan 11, 2005 | 08:13 AM
Default Wheelies
Ya man I gotta' go to work -_-
Old Jan 13, 2005 | 04:20 PM
JoshyWashy's Avatar
Default Wheelies
yeah but wont that mess up my tranny because a wolverine is an automatic clutch
