Oil in the intake drain hole . . .
Got a 2004 Wolverine with a 50" Moose Plow. Was out in the blizzard plowing all day, and I noticed the intake drain plug filled up with something. Upon closer inspection, it was filled with a red liquid, I pulled the plug and about two tablespoons of the oil came out. I opened up the intake box and it appears to be oil from the foam air filer. I didn't re-oil the thing, why is it shedding oil like a ****? There was also oil at the bottom of the intake box???
Anyone???
Anyone???
Originally posted by: duke9074
mabye you put to much on or the cold box and the heat form the motor made condensation that caused water to tlak the oil off the filter
Thats just the excess oil, on the air filter. If the air filter still has a red tint to it, youre fine. Its probably been in there awhile, but all the back and forth of plowing made it settle in the tube.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
