What is up with this?
Old Jan 27, 2005 | 08:24 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default What is up with this?
Where'd it go?
when i got hoem for mriding today ( for 30-45 mins0 i noticed i had to light.. and nbow i can only tunr it on when i pull the clutch
Old Jan 27, 2005 | 08:33 PM
Banshee392's Avatar
You are not authorized to view this page
You do not have permission to view this directory or page using the credentials that you supplied.
Old Jan 27, 2005 | 08:34 PM
Speedy2222's Avatar
**** that's right... totally forgot about that .. srry it's a new FTP maybe seems40z will come on and fix it for me [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 27, 2005 | 08:36 PM
Speedy2222's Avatar
blah blah blah [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jan 28, 2005 | 06:49 PM
Speedy2222's Avatar
someone click the link and see what it does or says whe nu click it or try to d/l it..
Old Jan 28, 2005 | 07:03 PM
Raptorboy4life's Avatar
hahaha i stole the neutral light!!!!!!!!! har har har!!!!
Old Jan 28, 2005 | 07:07 PM
Speedy2222's Avatar
GIVE IT BACK!!!!
Old Jan 28, 2005 | 07:13 PM
2phast4u's Avatar
you should take off all the front nose piece and look at the wire goign into the light and see if everything is tight if so call your dealerand c if they have a new bulb or w/e it is u havfta do to replace it
Old Jan 28, 2005 | 07:19 PM
wfo660r's Avatar
try checking things like the switch on the clutch lever that tells the engine if the clutch is pulled in so the engine will start. there are also two little fuse box lookin things on, i believe, the right side above the rear tire, just under the fender. usually one is yellow and the other is green. those are your neutral and reverse relays. pull them out and switch them around and see if your neutral light works and your reverse light doesnt. if that's the case, then the neutral relay is bad. other than that, just check the wires. i had my warrior a long time ago, but i remember there was something electrically wrong with it, and it was 1 wire that connects to a stud sticking out of the case below the shifter shaft. it came off and had my mind boggled for a while. good luck.
Old Jan 29, 2005 | 12:13 AM
Vinson581's Avatar
you made my night, and full filled my laughter, now i can sleep in piece.....
that was a pretty funna a$$ video if i do say so myself....
v581
