HELP weird squeeking/popping noise
I was riding today and i kept hearing this squiking/quiet popping noise and didn't no where it was coming from.It seemed to make this noise when i would let off the throttle,i would also hear it when i was wheelieing,but i would hear it when it came down like on the shocks.So i don't know if there maybe something wrong with my shock or something internal,but it ran fine all day today.Anyone have any clues.
if the noise is in the rear,,,,,,,,it is most likely your axel bearings
jack the rear,,,,,and give er a wiggle
dont ride if thats what it is,,,,,,you can do further damage to your bearing carrier
Well i guess it was random,because i would hear it sometimes (probably every minute or so)mostly when i would give it gas and let off the throttle.It also did it everytime i came down from a wheelie.
alright i did that and it didn't squeek.How would i know if it was the bearings?
if the axle wobbles,,,,,your bearings are shot
it will start out as a random crunch,,,and progress to random popping as the bearing start to break up
the farther you go on em,,,,the more potential damage you will do to the bearing carrier
alright i'll try that tomorrow.Today i saw that i had a really loose bolt in the rear,its the big bolt that loosens and tightens the chain.I tightened it back,but don't know if it had anything to do with it,because i haven't got to ride it yet.I'll check tomorrow to see if it was the bearings.I'm hoping that bolt had something to do with it.But i did ride it alittle this morning (before i saw the bolt)and it seemed like the noise was coming from the right side in the engine.Could it be the clutch or something?By the way thanks for the help so far.
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
