Flags, what materials?
Old Feb 6, 2005 | 05:23 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
Default Flags, what materials?
what kind of material do you use for flag poles?? and what abotu the flag itself?? i wnat to make my own.. don't know if it saves $ or not but im still gonna do it..
Old Feb 6, 2005 | 05:52 PM
blindside350's Avatar
Metal (like Aluminum alloy? sumthing like that) or Fiberglass (or thats what is looks like) They flag its self is probably made of some plastic ish stuff...But then again you could always use Bright Colored ducttape [img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 6, 2005 | 05:58 PM
Speedy2222's Avatar
yea... ok.. w/e i just need to know what material the flag pole is made out of..
Old Feb 6, 2005 | 06:10 PM
INSeaRChOFDUNez's Avatar
atv whips are made of fiberglass
Old Feb 6, 2005 | 06:27 PM
Speedy2222's Avatar
onto the next ?... where do i get fiberglass poles for cheap?
Old Feb 6, 2005 | 06:48 PM
Carnivore's Avatar
You might have to buy a stock pole and flag and cut the flag off. They are prolly available somewhere for cheap in bulk because most places around here have advertiseing for their stores printed right on the flag. Rocky mtn ATV for example.
Old Feb 6, 2005 | 07:38 PM
Speedy2222's Avatar
my dad has some old banners with flag things on them.. im just gonna use those.. for the flags.. but just can't find fiberglass flag poles anywhere... i think im gonna check menards or home depot.. idk does anyone work there that could tell em if they got m or not?
Old Feb 6, 2005 | 07:59 PM
Hippyhunter's Avatar
WHY DO YOU INSIST ON MAKING YOUR OWN FROM SCRATCH?
ITS GOT TO COST MORE TO DO IT THAT WAY.
GET A FLAG FROM YOUR LOCAL GOLF COURSE SUPPLY AND MOD IT.
GET A DRIVEWAY MARKER REFLECTOR AND MOD IT.
BOLT A 2X4 ON YOUR GRAB BAR THAT WAY YOU WOULD HAVE A ROLL OVER STICK TOO.
AGAIN I DONT GET IT BIG DAN WHY YOU WOULD WANT TO FABRICATE SOMETHING THATS READILY AND LESS EXPENSIVILY AVAILABLE.
BUT IF YOU DO MAKE ONE MAKE IT TO SPEC'S SO YOU CAN USE IT ie: FLAG SIZE COLOR AND SHAFT HEIGHTH.
ENJOY.
EXAMPLE:HEY I AM GONNA GO BUY A BUNCH OF PAPER TOWELLS AND CUT IT INTO THIRDS AND MAKE TOILET PAPER OUT OF THEM.
JUST KIDDING...NO REALLY....NO I AM NOT.
Old Feb 6, 2005 | 10:27 PM
Speedy2222's Avatar
well see the stealership sells them for like $20 for a 7foot flag( to tall for where i ride but flags are req. soi i have t ohave one) and this place is so easy to flip it's just easier to make like 10 .. so you know you always have one or 2... also rocky mountain use to have these pop-it flags with the spring on the end and were 6 foot ( 5-6 ft is what i need)
Old Feb 6, 2005 | 11:31 PM
AHA! THATS MAKES SENCE THEN.
MAYBE USED DUNE BUGGY WHIP MADE OF STAINLESS STEEL ON A SPRING WOULD BE GOOD AND TOUGH. I HAVE TWO KINDS ONE THAT BREAKS AND ONE THAT DOES NOT. BREAKS IS MOUNTED IN A DRILLED BOLT HEAD AND IS JUST AN EPOXY'D FIBERGLASS SHAFT INTO THE BOLT HEAD. THE OTHER WHICH WORKS AND DOES NOT BREAK IS A SPRING BASED FIBERGLASS SHAFT.
NEITHER ONE IS QUIK-RELEASE THO. (NUT n BOLT)
WHATS THE BEST QUIK-RELEASE OUT THERE GUYS?
