Do I have to get it Jetted?
Old Feb 10, 2005 | 09:24 AM
Warrior02man's Avatar
Default Do I have to get it Jetted?
im getting a pro Flow Kit with K & N air filter with no air box lid. Ive heard I need to get my quad jetted because of this. Is this true? What if I do not get it jetted?
Old Feb 10, 2005 | 09:25 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
yes.. but y run no lid if u have no slipon...?
Old Feb 10, 2005 | 09:29 AM
i dno.. more air? fine, i will keep the lid on.. but what if I do not get it jetted?
Old Feb 10, 2005 | 09:32 AM
Speedy2222's Avatar
if i were you wait till u get the slipon then run o lid but bsure to bumpuo your main..
Old Feb 10, 2005 | 09:34 AM
what if i get the air flow kit and the filter, but don't jet it? Ill leave the lid on..
Old Feb 10, 2005 | 09:41 AM
CamoKodiak450's Avatar
Has Been Around Here Quite Awhile!
You probaly should rejet atleast up one or two sizes on your main jet. If you dont , with the extra air coming in it's going to make it run lean which means HOT. If it really bad it could burn a hole in your piston. I suggest you do it your self. I did it just last week. First learn about it on the net. There is a lot of web sites on rejetting. Do a search. Theres not much to it. Take the carb off, remove the bowl, unscrew the main jet and screw the new one in. Dont over tighten.
Old Feb 10, 2005 | 02:25 PM
-bump-
how long can I go without it being jetted?
Old Feb 10, 2005 | 02:47 PM
When you get your new K&N airfilter installed take it for a ride with the lid OFF. You will soon learn what LEAN is. When you let off the gas it will backfire and crack and pop.That is with the lid off or vented. Iwould leave the lid on and you probaly would be all right with stock jetting.With the lid off you must rejet to add more gas to the increased air flow. Try it both ways and then you will understand this more when you are able to see it for yourself. Do a search on rejetting and read everything you can and in a week you"ll know more than most. Like I said before, If you leave the lid on you will probaly not hurt anything unless you hear all kinds of backfire and popping
Old Feb 10, 2005 | 02:59 PM
ok.. thx alot.
ReconBayou
Oct 31, 2022 05:37 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
