wolverine 424 select
Old Feb 10, 2005 | 09:48 PM
jax04wolverine's Avatar
Default wolverine 424 select
hey guys just ordered my warn 424 and cant wait to get it. i plan on riding in 2 weeks so hopefully
it gets here in time. question though was install difficult? can you wheelie easier with it engaged?
ive read other posts and am very excited from all the feedback on it thaks people[img]i/expressions/face-icon-small-happy.gif[/img]
Old Feb 10, 2005 | 09:51 PM
Madwolverine's Avatar
Pretty easy install. It would help to have snap ring pliers. Take a look at my pictures for a better idea on how to mount the controller.
You can't wheelie any easier in 4x4 or 2x4. You will love the 424 though.
Old Feb 10, 2005 | 11:34 PM
wr250's Avatar
I just installed this the other day and as Madwolverine stated it was a pretty easy install. I tipped the Wolverine over on its side so that I wouldn't have to crawl under. Make sure you redirect your fuel tank vent when you do this or gas will flow out while the Wolvy is on its side. It took approximately 2 hours without rushing, connecting everything and test riding. The instructions that came with it were excellent. Lots of pictures. The hardest part was removing the clips as I did not have snap ring pliers. I put the drive shaft in the vise and used two regular pliers to get the clips off. Also be careful when you take the controller end off to route it to the mounting location. If you take the brass part out there is a small ball bearing that could be easily lost. I mounted the controller in approx the same location as Mad.
BTW I picked up my 424 from ATV Direct. $220.00 delivered.
This is an excellent mod.
Good luck.
Old Feb 11, 2005 | 10:22 PM
WolverineMan15666's Avatar
When I installed mine, I had the old driveshaft out and everything loose and ready to go. That saved me a little time. When the UPS truck delivered it, I was ready to install. You'll have to loosen the a-arm bolts to get it in. The instructions are pretty clear and easy to understand. You shouldn't have a problem. Be careful on your first ride. I almost rolled mine the first time I took it for a spin in the yard. The Wolverine steered so much easier that its easy to over steer when your not use to it. You'll love it. You can do power slides and donuts just like the sport quads. It still won't wheelie very good though.
suzuki230
Jul 8, 2016 10:03 AM
panicmanic
Dec 15, 2015 01:58 AM
carid
Sep 14, 2015 03:40 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
