My Patriot dune-port has arrived!
Old Feb 11, 2005 | 11:33 AM
Izord's Avatar
Default My Patriot dune-port has arrived!
Banshee Patriot dune-port engine has arrived! Sitting in a crate in my brother's garage.
110 octane Noss heads. Lock-out clutch, billet basket, polished cover.
New carbs, V-Force reeds. Got my Toomey T-5's in my truck.
Dyna-FS ignition module in the box.
Got a week off from work!
Wish me luck, pictures next week. I'll show you my trick Blaster too. Don't rag me on the rack and box I put on the back of the Blaster.
Izord
By the way, turn around time: I sent Dan my motor in October.
Old Feb 11, 2005 | 09:36 PM
Banshee392's Avatar
Izord
Sweet! But a rack and box on your blaster? :-/
Old Feb 12, 2005 | 01:31 AM
bad350twin's Avatar
Lockout clutch for a dune port?
Old Feb 12, 2005 | 01:36 AM
Izord's Avatar
Yes, My horsepower is supposed to be in the upper 60's now. Look at the bottm of this page for the clutch:
http://www.patriotracing.net/Banshee.htm
Old Feb 12, 2005 | 05:09 AM
ZillaRider02's Avatar
A lockout really isn't needed until you reach the 80+ Hp range...................
Old Feb 12, 2005 | 11:45 AM
Izord's Avatar
Recreational Sex isn't "needed" either, but I like it!
Izord
Old Feb 12, 2005 | 11:48 AM
Shav0's Avatar
Hahahah, don't we all.
Old Feb 12, 2005 | 12:26 PM
Izord's Avatar
I'll tell you about the box on my blaster. It's for carrying stuff like a few tools, sammiches, "refreshing" drinks, and stuff I might need.
I started off with a tubular rack that bolts on to the stock grab bar.
Then I got this Box: http://www.rockymountainatv.com/Prod...v?pid=00081995
It's the FRONT box for a ute ATV. But it fit perfectly on the BACK of my blaster.
It's really light, and I don't think it affects the handling at all, You can't tell its there until you get off the bike for a "refreshing" drink. ; )
It cost 74.99$ and I put it on so the opening part faces backwards, so I can open it from the back of the bike.
On my 'Shee I have a "six pack rack". For a little cooler, also for "refreshing beverages".
Peace, out.
Izord
Old Feb 12, 2005 | 06:41 PM
bad350twin's Avatar
my thoughts exactly.... im my area, the only banshees with lockouts are from the overridden alky350 with drag ported cylinders! You usually only see very few of those with lockouts ! U sually they start using them on the 4mm and up strokers.
Old Feb 12, 2005 | 07:52 PM
JakalWarrior's Avatar
Arent they really for override trannies since they make it hard as heck to pull in the clutch when the motors reved, so youd really be slower in a drag because of horrible clutch pull.
Im trying to do something with my clutch too though, I hate blasting through the gears then about halfway through one the motor just revs out.
