2 quick questions please
Old Feb 14, 2005 | 02:21 PM
Brian5150's Avatar
Default 2 quick questions please
1.) Are the carbs from all 660 raptors interchangeable from year to year (2001 on 03, etc.)
2.) I'm leaking a small amount of coolant from the bottom of my water pump, where the cover goes on. Probably just a gasket??
Thanks
Brian
Old Feb 14, 2005 | 02:26 PM
jrobertson's Avatar
Yes all interchangeable. I am having the exact SAME problem from my Water Pump. I talked to the dealer and he said it sounded like my water pump was going out. He said for the parts it would be around $35. I just havent had time to pull it apart and checked. I thought it was just an o-ring or gasket also.
Old Feb 14, 2005 | 08:27 PM
camshaft9's Avatar
could be a gasket or need a new pump mine started doing it but it was my drain bolt it vibreted lose becaus i didnt tighten it enough when i put my supper cooler in i drained the anti freezeit and i didnt tighten it down enough when i put bcak in because it was so small i was worryed about it stripping
Old Feb 14, 2005 | 09:21 PM
Rider1169's Avatar
at least your not leaking oil up through a bolt in the engine [img]i/expressions/face-icon-small-sad.gif[/img]
cornermike
Sep 10, 2015 08:30 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Rooky
Sep 9, 2015 03:16 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Logan Collins
Sep 5, 2015 08:03 PM
