05 raptor problem with first gear
Old Feb 14, 2005 | 09:02 PM
zhundredrider's Avatar
Default 05 raptor problem with first gear
Just bought raptor and i'll start it up and let is warm up and then when i put it into first gear the bike just shuts off.
and when i do it again it sometimes does it.
But after i ride it just like 15 ft it doesn't do it again. but after it sits for a few days or the next time i go ride it dose it all over again.
Anybody with similiar problem or have idea to was is causing this?
Old Feb 14, 2005 | 09:08 PM
Rider1169's Avatar
could be your clutch is just too loose? if i dont ride mine for a while, and i put it in first it jerks and stalls, so i keep up the revs a lil, or tighten the clutch. doesnt sound major.
Old Feb 14, 2005 | 09:09 PM
caliraptor's Avatar
Thats normal...I think its because the clutch is cold/dry. The 3 quads we have do that when cold...dont worry about it..just let it warm up
Old Feb 14, 2005 | 09:11 PM
when i bought my bike i picked up the gyt-r clutch kit so if i install that u think it solve the problem
Old Feb 14, 2005 | 09:14 PM
caliraptor's Avatar
no
Old Feb 14, 2005 | 09:15 PM
even when i let it warm up it still does the same thing
Old Feb 14, 2005 | 09:22 PM
caliraptor's Avatar
You can loosen your clutch if you want...its not a problem. Most bikes do this when new or the clutch is adjusted properly.
Old Feb 14, 2005 | 09:24 PM
so just wait and see huh?
it only has about 13 hours on it and i'm going to the dunes so maybe it'll go away after a long weekend of riding
Old Feb 14, 2005 | 10:06 PM
86LT250RFatty's Avatar
well, when i first put my bike into 1st gear, it like jumps then goes in. Try playing around with the clutch cable slack, maybee your clutch isnt fully engaging. also check your oil?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Feb 14, 2005 | 11:49 PM
Raptor149's Avatar
Dude, just adjust your clutch! It only takes two 12 mm wrenches. Just do it in small, tiny increments. These clutches are very sensitive. If you're bike is new, you won't need the new kit yet. Hold onto it for a season or two, depending on how bad you abuse the stocker.
toonces
Oct 16, 2019 12:11 PM
AtvManiac78
Jul 11, 2015 03:20 AM
winterwolf
ATC 3-Wheelers
Jun 3, 2015 07:34 PM
RaptorGuy01
Oct 31, 2000 04:23 AM
