raptor banshee
Old Feb 27, 2005 | 12:48 PM
raptorRACER16's Avatar
Default raptor banshee
what do you mean by tuned right?
Old Feb 27, 2005 | 11:30 PM
Buford77's Avatar
Jetting.
Old Mar 1, 2005 | 12:50 PM
maddog56's Avatar
Originally posted by: raptorRACER16
what does a raptor need to beat a banshee with a fmf pipe system, K&n, and it is bored out
with a 692 kit and pipe and filter i think the raptor could take it what do you guys think
What is this 692 kit? That would be .100 over and a 102.5mm piston, which I've never seen any company make. .080 over is pretty much the limit for the stock cylinder, anything over that requires a new sleeve and case work.
So is this a new sleeve or is the engine builder going to unrealistic tolerances on the cylinder walls and creating a time bomb?
And unless you install a higher compression piston and new camshaft you arent going to see more than a couple hp out of a big bore. Basically its useless.
You need to do some research, and tell us where you heard about this "692" raptor kit...
Old Mar 1, 2005 | 09:25 PM
alright so do you think i should just get the stage 2 cam kit with the kibble springs ?
i saw it on a search on um i think google some guy said he had it and he loved it so i thought oh cool
Old Mar 1, 2005 | 09:48 PM
  #15
86LT250RFatty's Avatar
Get a Web Cam 696/697 Grind Cam, Get a Stock Bore 11:1 Weisco Piston, and Kibblewhite valve springs, you need all 3 to make good power reliably, you need a piston when doing a cam to get most performance, the above cam will increase power all over the board, and still run on premium. good for a handfull of horses.
Old Mar 1, 2005 | 11:17 PM
  #16
RoostKing's Avatar
why would you even bother boring it, you could take banshees on a stock bore with some other mods. alot of people dont know it but an extra 32 or somthing like that cc's dont make a huge difference. the power comes mainly from the parts used with the bored out engine.
What he said and also go with 86lt250RFatts Raptor suggestion.
Roostking....
Old Mar 4, 2005 | 09:28 PM
  #17
alright ill save up a little more money and i will the the cam stage 2, kibbile springs, and a 11:1 piston
then i should beat the banshee right?
Old Mar 5, 2005 | 11:37 PM
  #18
maddog56's Avatar
Thats all it took for me to beat my friends and thier piped banshees.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
