rich or lean?
Old Feb 27, 2005 | 11:46 PM
raptoric's Avatar
Default rich or lean?
would running lean be more damaging to engine than running rich?
Old Feb 27, 2005 | 11:51 PM
Rider1169's Avatar
running Lean is terrible for your engine. running rich hurts nothing other than fouling plugs.
Old Feb 27, 2005 | 11:53 PM
Doctorturbo's Avatar
GOT BOOST!
Lean= Holes in and melted pistons.
Rich= Fouled plugs, carbon build up and thinned out oil.
Old Feb 28, 2005 | 12:19 AM
blindside350's Avatar
Lean makes your engine run hotter which will end up with mucho engine damage... Rich is alot better, all it does is foul plugs and maybe some carbon build up. If you're planning to jet, start high then work your way down.
Old Feb 28, 2005 | 12:29 AM
raptoric's Avatar
the reason im asking is ive got a mild port job,stage 1 hot cam & 11:1 piston.
i did a search and have read conflicting reports on needing to re-jet or not
i have already jetted up for exhaust and air box
any thoughts
Old Feb 28, 2005 | 12:41 AM
caliraptor's Avatar
You will need to re jet. We have similar mods and Im running 185/190 dynojets.
Old Feb 28, 2005 | 12:42 AM
NBake's Avatar
to be totally sure, do a plug check. find a stretch where u can rev a couple gears out, shut the motor off while runnin hard and coast it back. take the plug out and if its tan its good, if its black and wet its rich, and if its dry and white then its lean. there was a post up that had really good pics of different plugs and their running conditions.
Old Feb 28, 2005 | 12:44 AM
NBake's Avatar
and here it is http://forums.atvconnection.com/mess...did/442044.cfm
thanks speedy!
Old Feb 28, 2005 | 01:54 AM
Slowwarrior's Avatar
Running to rich is not good either. It thins the oil which in turn starts to burn up the rings. Then you will end up with oil burning ride. But lean is a definate NO, NO. No matter what mods you do always check your jetting.
Dammar
Apr 20, 2016 06:03 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
bvolks
Sep 13, 2015 12:57 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
