how do u convert a big bore to find the CC's
Subscribe
Mar 8, 2005 | 11:58 PM
like my buddy has a 84mm bore and a 64.5 stroke and he wants to know how many cc's it is and i dont know what formula u use to get it
Reply 0
Mar 9, 2005 | 12:13 AM
i thought it was just bore times Stroke
Reply 0
Mar 9, 2005 | 12:26 AM
Should be radius of the bore squared, times 3.14, times the stroke, and then divide by 1000 to get cc's. Your buddy has around 357 cc's.
Reply 0
Mar 9, 2005 | 12:29 AM
I forgot, for multiple cylinder motors, multiply that number by the number of cylinders.
Reply 0
Mar 9, 2005 | 12:46 AM
ok on the compression like 10:75:1
what does each numeric value represent
10 75 1 ???
Reply 0
Mar 9, 2005 | 01:10 AM
Compression ratio is how much space in in the cylinder at the bottom of the stroke compare to amount of space when it is at the top
Reply 0
Its 10.75:1
Reply 0
Mar 9, 2005 | 01:26 AM
10.75:1
ok for an example
at the bottom of a stroke you can give it a value of space being 10.75
and at the top you can give it a valve of space being 1
the numbers represent the amount of space, but what are the numbers 10.75psi 10.75mm 10.75cc 10.75in ??????? 1mm 1cc 1psi????
Reply 0
Mar 9, 2005 | 01:41 AM
At the bottom of the stoke you would have 357cc and the top you would have 33cc
Reply 0
Mar 9, 2005 | 02:22 AM
or it compresses the fuel/air mixture 10.75 times
Reply 0
