? BENT STEERING STEM ?
Old Mar 13, 2005 | 05:55 PM
400exKiller990's Avatar
Default ? BENT STEERING STEM ?
went ridin.. clipped a tree,which turned the bars to the max...[img]i/expressions/face-icon-small-disgusted.gif[/img] now as it sets the wheels are straight but the bars are turned to the right a lil bit. i cant tell whats bent by lookin at it but anyone know what might have bent or if theres a way to find out whats bent. sounds like a dumb question but thanks
Old Mar 13, 2005 | 06:06 PM
BaD04WarrioR's Avatar
Could be the tie rod it sounds like. You hit it withe the tire right. And are both tires turned when the bars are strait. But Id check the tie rods. You might have to take them off to look at it better. Or if they arent bent you might have to adjust the allignment
Old Mar 13, 2005 | 06:09 PM
EVERYTHING is visibly fine thats what i dont get all tie rods and ends are ok
Old Mar 13, 2005 | 06:13 PM
than you probably need to re-adjust the allignment.
Old Mar 13, 2005 | 06:21 PM
the alignment is right on i adjusted it after the incident it steers fine it just when the tires are straight the bars are turned to the right a bit[img]i/expressions/face-icon-small-confused.gif[/img] i dunno
Old Mar 13, 2005 | 06:37 PM
Well How did you hit the tree. Just with the tire itself. Where the tie rods connect to the steering stem...it could be tweeked or almost twisted a little bit. My steering stem was that way. The tires were strait but the bars werent. Id bet its the stem. The only way to tell is to take it off and look down it
Old Mar 13, 2005 | 07:11 PM
yea might be...im gunna do somemore adjusting and see how it turns out but if not looks like i have to fix sumthin thanks
Sep 30, 2015 01:37 AM
35dodge
Sep 29, 2015 09:40 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
Albertaboyy
Sep 9, 2015 09:51 AM
meddy0388
Sep 9, 2015 06:41 AM
