backfire w/ hmf pipe
Old Mar 13, 2005 | 10:25 PM
YFZ450Hornet's Avatar
Default backfire w/ hmf pipe
On my 05 YFZ 450 I just got a hmf put on and run an open air box with pro flow k&n and it is jetted at 170. After going full throttle and let off of the gas and slows down there is a backfire. Happens more often then I would like. I had the pipe and jetting done at the dealer so what can I do to take the backfire away? Is it too lean or what?
Old Mar 13, 2005 | 10:45 PM
86LT250RFatty's Avatar
go up one size on your Piolit jet, and turn your air screew out 3 turns, YFZ's are jetted lean from factory.
Old Mar 13, 2005 | 11:16 PM
blindside350's Avatar
Yea get a size up Pilot (which is 48) and just adjust the the fuel screw till' you have fresh crisp throttle response
Old Mar 14, 2005 | 02:04 AM
Madwolverine's Avatar
I'd try going out on the fuel screw before changing the pilot. If that does not work, then change the pilot.
Old Mar 14, 2005 | 10:52 AM
CobraR6's Avatar
I have an 04 Bruin 350, and it is stock. The same thing happens to me when going from full throttle to letting off the gas, it will backfire. Is there anything I can do to stop this?
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
greg86hd
Sep 16, 2015 12:32 AM
Brandon400
Sep 7, 2015 12:20 PM
