Still Lookin'
Old Mar 18, 2005 | 03:08 AM
Refalovr's Avatar
Default Still Lookin'
I need to replace my starter clutch on my rappy.I'm in desperate need of a manual for torque specs.Can anyone help with a manual in pdf format?
2002 Troy Lee Edition Raptor
gyt-r handgaurds
billet aluminum keydash
white bro's e-series pipe
Old Mar 18, 2005 | 03:10 AM
fast700rappy's Avatar
what torq spec.? on what?
Old Mar 18, 2005 | 03:16 AM
Refalovr's Avatar
Ugh, flywheel nut,cover bolts,etc...want to put it back together the right way ya dig
Old Mar 18, 2005 | 08:13 AM
Turbo33's Avatar
If your looking to replace the one way starter bearing the spects are 16Nm (1.6kg.) or 11ft.lb. This is for the bolts that hold the one way to the ac magneto rotor.
MAKE SURE YOU USE LOCTITE !!!
Old Mar 19, 2005 | 01:40 AM
Refalovr's Avatar
bumpin' it.....
Old Mar 19, 2005 | 02:04 AM
XR650Warrior's Avatar
around 75 ft. lbs. should do it for a flywheel
Old Mar 19, 2005 | 02:10 AM
Cover bolts are usually 6-9 ft. lbs. in most applications or (80-100 inch lbs.)
Old Mar 19, 2005 | 05:36 PM
Refalovr's Avatar
BUMP
flatcroaker
May 27, 2015 05:57 PM
WILDERP
Feb 26, 2001 07:01 PM
Mudskipper
Feb 14, 2001 04:26 PM
