Raptor Jetting is way off help me
Old Mar 18, 2005 | 08:22 PM
redwingsrule05's Avatar
Default Raptor Jetting is way off help me
I am trying to jet my raptor with a full exhaust and k&N with no lid. As close as i can get is 155/160 mains with a 25 pilot and 3/2 turnsd out on the air screws. The midrange pulls fine but it won't idle well, stumbles off the start, and dies out after about 6500rpm in any gear. It cuts out on the top really sharp, almost enough to throw you over the handlebars. Any suggestions on what i need to do, i have tried all the clip positions with no result. Thx
Old Mar 18, 2005 | 08:57 PM
petedog's Avatar
Have you done a plug check? (get W.O.T. for about 1/4 mile and then pull the clutch and kill it) Tell us your plug color. What brand of pipe is it?
If its like a yosh etc. you should be a little bigger in the mains. 160/165 25 pilots. I would also recommend you check the float level on the carbs itself. You might be running out of fuel in the bowls at W.O.T. and that is killing it. Good luck.
Old Mar 18, 2005 | 09:08 PM
caliraptor's Avatar
also need your elevation
Old Mar 18, 2005 | 10:36 PM
its a big gun pipe and muffler, im at 5200 feet, i can't get to WOT becuase it cuts out after you get up in RPM's. How do I adjust the floats, and which way do i go?
Old Mar 18, 2005 | 10:37 PM
Should i go 160/165 in the mains first?
Old Mar 18, 2005 | 10:44 PM
petedog's Avatar
http://www. blue traxx.com/phpBB/viewtopic.php?t=50521
Its alot to explain but here is a link. Again , take the spaces out of the link to get there. only 2 spaces(one right after the www. and one after BLUE)
and for the jetting....
http://www. blue traxx.com/phpBB/viewtopic.php?t=26458
Good luck!
Sorry about the spaces but this site wont let the word "BT" on their site for some reason.......
Old Mar 19, 2005 | 12:41 AM
caliraptor's Avatar
Sounds like your too rich. Im at sea level and Im running 150/155 with no lid. So if your at 5200ft, you should be a couple jets lower than me. Try going with 148/150.
bmxatv10
Oct 14, 2022 06:23 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
