pilot jet please help im stumped
Old Mar 20, 2005 | 08:00 PM
superevil's Avatar
Default pilot jet
Well,i need some advice. 2 stroke motor. this is for a lt250r but there seem to be more knowledgeable people in here. Stock pilot is a #30,and stock main is 240. I have an aftermarket pipe,and a clamp on K and N filter (no air box) Right now i know i have a 280 main jet and a #37.5 pilot. it starts easy but it is actualy harder to start with the choke on.and if you turn the choke on right after you start it it will die. It doesnt rev out very well unless the air screw is 1 and a half to 2 full turns out. I did a plug chop w.o.t. in 3rd gear,and the plug seemed fine for that range(dark brown). but when i let it sit at idle for like 5 minutes,and look at the plug,it is wet but the porcelan looked really bright. 37.5 is 3 steps over stock for the pilot. im thiking maybe i should step down 1 or 2 on the pilot so i can turn the air screw in a bit? i need pro advice. the choke not making a diference would lead me to believe im getting to much fuel.
ReconBayou
Oct 31, 2022 05:37 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
MPDano
1) Engine problems..
Sep 20, 2015 09:48 PM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
Hw00d
Sep 10, 2015 08:53 AM
