raptor pipe
Old Mar 21, 2005 | 10:13 PM
raptorider660's Avatar
Default raptor pipe
wat is a good pipe for a 660r raptor thats not to loud i was thinking something like a white brothers or yoshimura pipe
Old Mar 21, 2005 | 10:27 PM
TBONE31's Avatar
Default raptor pipe
usually the white bros and yoshi are loud but if i were you i would look at the HMF's. Thats what im getting for my quad.
Old Mar 21, 2005 | 10:38 PM
rotty150's Avatar
Default raptor pipe
I put an HMF on my rappy and I like it alot, the HMF flows a little more than most pipes so I had a heck of a time rejetting it, if you go HMF you will get the best bang for your buck!! It is pretty loud though??
Old Mar 21, 2005 | 11:05 PM
Default raptor pipe
i want something thats not that loud cause i get the cops called on me
Old Mar 22, 2005 | 12:02 AM
Default raptor pipe
thanks for the suggestion
Old Mar 22, 2005 | 03:18 PM
CTracingraptor's Avatar
Default raptor pipe
are you willing to compensate horsepower for noise? the pipes that make the most power put out the most noise.
Old Mar 22, 2005 | 11:38 PM
duneittilludie's Avatar
Default raptor pipe
If you are willing to spend the money then a LTE dual system is pretty hard to beat especially from mid range to top end.The LTE can be made to run fairly quiet with the addition of the quiet core inserts and although it does effect performance some it still produces a good overall power gain while running quieter.
Old Mar 22, 2005 | 11:45 PM
Default raptor pipe
thanks for about how much do they go for?
Old Mar 22, 2005 | 11:58 PM
Default raptor pipe
You can find the LTE for 659.00 at www.on-dunes.com.I am not sure if i should be giving that information out or if it is breaking the rules but i guess i will find out.If you could experience the top end of the LTE for yourself i think you would want a set for your raptor.If you do order the LTE pm me about the jetting that i use and i will compare your elevation and see if it will work for you.
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
black_thunder
Sep 22, 2015 07:59 PM
greg86hd
Sep 16, 2015 12:32 AM
Alex Rodak
Sep 12, 2015 09:39 AM
