high compression or big bore.....?
Old Mar 22, 2005 | 06:54 PM
tatertott450's Avatar
Default high compression or big bore.....?
i have an 04 yfz and want more power. im looking at high copmression piston and 470/480 big bore kit. what is the diference in reliabilty, and is the mod worth it?
Old Mar 22, 2005 | 07:14 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
if i were you. do both the cam mod AND a high comp piston. now THAT will add some power [img]i/expressions/face-icon-small-smile.gif[/img]
Old Mar 22, 2005 | 07:44 PM
MSGT's Avatar
True.
The big bore increases volume, but the compression supplies the pop! None of this will make a real big difference if the old cam won't let the engine breathe to take advantage of it. Performance is not a single part, but several working in concert.
Old Mar 22, 2005 | 09:04 PM
HughJazz's Avatar
I would go big bore or add some aftermarket cams. If you bump the compression up to high you will have to run race gas
Old Mar 22, 2005 | 09:36 PM
Fastblasterboy's Avatar
Wouldnt you have to get a heavier duty clutch kit for it with all the added power, it would rip the stock one apart wouldnt it?
Old Mar 22, 2005 | 09:52 PM
holeshotz8436's Avatar
deffinatly go with the cam but why dont you just find a big bore kit that has a hi compression piston that way you get more compression and more cc's. Check out www.cycleworksracing.net. They have a 500cc big bore kit and i think it has i hi compression pistion that brings you up to 13:1 from the stock 10:5:1 and while your in the engine you should get the oversized valves too, that will give you another few hp too
Old Mar 22, 2005 | 09:58 PM
garrett5462's Avatar
both would be best... but in yur case, get a big bore kit. just my .02
Old Mar 23, 2005 | 01:34 AM
HughJazz's Avatar
stock compression is 12.5 to 1
Old Mar 23, 2005 | 03:37 AM
maddog56's Avatar
Stock compression isnt 10.5:1 Holeshotz, and its not 12.5:1 either. It's 11.9:1 and always has been on the yfz.
Old Mar 23, 2005 | 11:10 AM
MSGT's Avatar
If you go much past 11:1 compression, you are looking at Octane problems (just to be aware).
