Raptor Grinding Noise? Please help!
hey all. lately my one-was has been on a one-way road to the dump.(hehe thats a good one) Sometimes it would free-spin, ide just rock the quad and it would allways grab. today i just finished working on my carbs, and i go to fire it up and it starts and runs fine. then i go to pull it into my driveway and like it would go smooth, then like every 10 ft or so i would hear this grinding sound coming from the engine ( i have no idea what part) and if i would Stop in that like section, it would just grind, i dont know what this noise is! the engine runs fine and the one-way still starts. it doesnt make the noise untill the engine starts. I took the cover off where the oneway is, and i could turn the engine over with the flywheel ( i think thats it) and when i turned the engine over it was smooth and no grinding noise... im pretty sure its the oneway just want to make sure befor i spend the 200$. thanks, also, if it is the oneway just grinding, is it ok to ride it like that? like will it go away.
Not sure what you are saying in detail. Did you say that when you are cruising you get a grinding sound every 10 feet?
When my one-way went bad it never made a bad sound when the engine was running. Every 3 starts or so the starter motor would free-spin couple of times then make a big clang sound and a brief grind when it would engage. Did this mostly when the engine was warm.
The LA one-way I put in works flawless.
pieces of your one way could have broken loose and be caught near some moving parts.....
probably even stuck to the flywheel magnet and contacting the stator as it rotates
just a guess i guess[img]i/expressions/face-icon-small-smile.gif[/img]
jrooker6
Apr 23, 2016 07:36 PM
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
