Why wont it start?
Old Apr 7, 2005 | 06:10 PM
jason399's Avatar
Default Why wont it start?
Ok.. my beartracker today was being fussy and when I turned the key there was no power.. so I checked the fuses and a fuse was gone so I replaced it and then checked someconnections everything was good and clean. Then I looked at the plug and cleaned it with a wire brush and put a little gas on it, put it together and boom it started... then I let it warm up and then I shut it off and now it wont start back up, so I put a new plug in all it does is turn over. It has gas the tank is full, and it is getting gas. Any ideas?
thanks guys
Old Apr 7, 2005 | 07:47 PM
redneckcav24's Avatar
Well first, dont worry about the fuses anymore because if it turns over ya got somethin. I would suggest trying to try charging your battery a little. My warrior wouldnt start and it was b/c my battery was so dead it lost most of its CCA(cold cranking amps) if that dont work for ya i dont know.
Old Apr 7, 2005 | 07:54 PM
warriorboy22's Avatar
My warrior wouldnt start i charged the battery and it starts right up. maybe you have water in your gas lines it happened to one of my friends quads it would turn over but wouldnt start i dont know how it was fixed he brought it to a dealer
Old Apr 7, 2005 | 09:10 PM
NECTrider's Avatar
Did you try pull starting it? That would rule out the battery thing. You do have a pull starter, right? My 97 Big Bear Does.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
