How to make Raptor Handle Better
Old Apr 9, 2005 | 12:22 AM
redwingsrule05's Avatar
Default How to make Raptor Handle Better
What kind of mods do you guys use to make your Rappy handle better? I need some suggestions becuase mine is getting a little rough and tipsy. Thx.
Old Apr 9, 2005 | 12:26 AM
RapDaddy660's Avatar
wider a-arms and axle, better suspension, there are a number of different things
Old Apr 9, 2005 | 12:33 AM
enFORCER's Avatar
Lower it....... Widen it.....
Old Apr 9, 2005 | 12:46 AM
Would changing into a different shock help at all, such as those of a 450yzf
Old Apr 9, 2005 | 12:48 AM
yeah
Old Apr 9, 2005 | 12:49 AM
enFORCER's Avatar
If it lowers it, it will...........................
Old Apr 9, 2005 | 01:40 AM
raptorRACER16's Avatar
i put the g force axle on mine helped out soooooooo much
Old Apr 9, 2005 | 08:46 AM
raptor010's Avatar
Well you see what I've done. Before I had stock shocks right. Like a dumbass out there trying to be cool on the MX track casing jumps and just flat out looking like I need to get off the track right. Well Putting on the ELKA quad rated shocks with +3 +1 a-arms and added +4 inches on the axle, man I just couldn't believe how it rode. I don't even have to lean into a corner anymore. The lands are so easy to take. Heck I look like I belong out there now. Can't wait for the 690cc.[img]i/expressions/face-icon-small-smile.gif[/img] SSG JACOBS
Old Apr 9, 2005 | 01:48 PM
TooFast2Pass's Avatar
Step 1: Remove plastics. Step 2: Buy YFZ 450. Step 3: Remove 450 plastics. Step 4: Attempt to bolt Raptor plastics on YFZ.
No, I'm kidding. Raptors have the potential to handle better with a little help from suspension work and ergonomics. Like everyone has pretty much said the number one thing to do is offset the height and high center of gravity by making the machine wider. +3 A-Arms would be a little extreme unless you plan on racing only because it will compromise where you can go in the woods if you are a woods rider. Try to get an axle that will make the rear end equally as wide as the front. Another thing you can do is get an axle that makes the width of the rear end just slightly narrower than the front i.e. 1". This will help the Raptor silde the back end around corners a little easier at high speeds.
Old Apr 10, 2005 | 03:22 AM
id get the g force axle cuz then u can put it +2 for trails and +4 for on the track its a great thing to have
