Making my raptor 350 wider
Old Apr 16, 2005 | 12:46 AM
boombaby's Avatar
Default Making my raptor 350 wider
Can i just flip my front wheels around.........or will i have to buy something?
Old Apr 16, 2005 | 12:52 AM
Carnivore's Avatar
i've heard of people flipping their wheels but then your valve stem is on the inside of the rim.
You'd have stuff a valve backwards inside your tire to plug the hole and then drill another hole on the outside of the rim to install another valve stem to fill it with.
Wheel spacers seem easier..
Old Apr 16, 2005 | 12:56 AM
boombaby's Avatar
How much would it cost to buy front and back spacers?
Old Apr 16, 2005 | 01:02 AM
Carnivore's Avatar
I'm not sure..
$60 or $70 per pair is my guess.
Old Apr 16, 2005 | 01:16 AM
VelociRaptor350's Avatar
I owuldn't suggest flipping your rims, if your gonna do it, do it right, axle and a arms.
Old Apr 17, 2005 | 06:12 PM
fessendenr's Avatar
flipping your wheels around is extremely bad for your bearings! Dont do it. Axle and A-arms is the way to go unless you dont want to spend much you can get front and back wheel spacers for $140.
Old Apr 17, 2005 | 06:57 PM
Scooter86's Avatar
Knows Old ATV Questions!
LOL, wheel spacers are just as bad for the bearings as flipping the rims! If you can afford a arms and axle, go for it. Wheel spacers and/or flipped rims will also work, but you will get more bump steer and an increased chance of bending your axle. Just keep the extreme flight time down and you will be OK though.
Old Apr 17, 2005 | 07:00 PM
holeshotz8436's Avatar
you could just buy wheeles with a diffirent offset to make it wider but the most you will probally get from that is an inch on each side
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
