plugs and pins on 2001 Raptor CDI -HELP
GREETINGS GENTS.
I'M TRYING TO DO A CUSTOM APPLICATION WITH A 2001 RAPTOR 660 CDI IGNITION BOX AND DON'T HAVE A YAMAHA FACTORY SERVICE MANUAL: IS THERE ANYBODY WHO MIGHT BE ABLE EITHER TO EMAIL ME A WIRING DIAGRAM THAT WOULD MAKE CLEAR WHAT EACH OF THE THREE PLUGS CONSISTS IN OR SIMPLY LIST THEM LEFT TO RIGHT?
ALL I REALLY NEED TO KNOW IS:
WHICH IS THE POWER LEAD (LINKING UP TO THE BATTERY)
WHICH IS THE GROUND
DOES THE GROUND GO TO THE FRAME OR TO A KILL BUTTON?
IF TO THE FRAME, SHOULD THE KILL BE ON THE POS OR THE NEG SIDE?
WHICH PIN GOES OUT TO THE IGNITION COIL
WHICH PINS ARE FOR RECEIVING IMPUT FROM THE PICKUP SENSOR/ROTOR ASSEMBLY
HELP!
JUST RECEIVED A FRESH CDI BUT EVERYTHING IS UNMARKED AND SIMPLY ASSUMES THAT YOU PLUG IN THE RAPTOR STANDARD WIRING HARNESS.
THANKS TO ANY AND ALL.
JEFFREY
schnapp@stanford.eduText [img]i/expressions/face-icon-small-smile.gif[/img]
WHICH IS THE GROUND
HELP!
JEFFREY
