removing front shocks
Old May 1, 2005 | 12:14 AM
psuperman112's Avatar
Default removing front shocks
i wanted to remove my front a arms to polish them but i've never taken apart the front end. i was just going to free lance it but then i thought if i get the shocks off how am i going to compress them to put them back on? anyways could somebody tell me the best way to remove the shocks, and any other tips about taking apart the front end?
Old May 1, 2005 | 12:18 AM
Rider1169's Avatar
Put the front end up on a block, under the front part of the fram, so the arms and shocks have no pressure under them, undo the top and lower bolts holding the shocks in, remove the shock, and the arms go limp as far down as it can go. To reinstall the shocks, push the a-arm up a little until the shock(totally relaxed and not compressed at all) mounts right up, throw in the bolts, and remove the block, and its back to normal.---Rider1169
Old May 1, 2005 | 12:22 AM
so are the shocks the last thing i remove then? sounds so easy when u put it that way [img]i/expressions/face-icon-small-smile.gif[/img]
Old May 1, 2005 | 12:24 AM
Rider1169's Avatar
Remove the shocks first. Just set it up on the block, and take out the 2 bolts on each shock, then remove your a-arms
Old May 1, 2005 | 01:56 PM
NastyNate03's Avatar
rider1169 basically explained it all when you do polish them let me know how it turned out i was thinking about polishing the a arms on my banshee but decided not to
Old May 2, 2005 | 05:19 AM
k i got around to doing one a-arm tonight and here's some pics of the stock vs the stock polished, i think i'm going to give it a little more sanding around the corners tomorrow though.
http://photobucket.com/albums/y186/psuperman112/
JackTheKing
Jul 14, 2015 09:09 PM
1966F100
Jul 12, 2015 03:08 AM
cSchwartz
Jul 9, 2015 02:40 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
