coolant
Old May 2, 2005 | 09:19 PM
richardsb's Avatar
Default coolant
I have a 2002 raptor 660 and was wondering how to flush and fill the antifreeze in my rappy. Just want to do some more previntive mantaince? Where can i find a free online manual for my bike to
Old May 2, 2005 | 09:21 PM
YamahaRyder4Lyfe's Avatar
Default coolant
www.blutraxx. com (without the space) and go to forums, then to raptor, and its stickied at the top
Old May 2, 2005 | 09:43 PM
richardsb's Avatar
Default coolant
tried that but get nowhere>
Old May 2, 2005 | 09:51 PM
Default coolant
sorry...www.bluetrax. com
Take out the space after the period, and add an "x" to trax
Old May 2, 2005 | 09:54 PM
420rappy's Avatar
Default coolant
maybe yamaha.com i think i saw one there[img]i/expressions/face-icon-small-confused.gif[/img]
Old May 2, 2005 | 10:54 PM
Pitfan04's Avatar
Default coolant
Ok, this is for an 05 model. It may be the same. Remove the coolant drain bolt. Remove the radiator cap. Remove the coolant reservoir cap. Dosconnect the hose on the coolant reservoir side, and then drain the coolant from the coolant reservoir. After draining the coolant, thoroughly flush the cooling system with clean tap water. Replace the coolant drain bolt washer if it is damaged, and then tighten bolt to spec. torque. 7 ft lb...Install the coolant res. hose. Pour recommended coolant into the radiator until full. Pour the recommended coolant the the coolant res. to the Max level mark. Install the radiator cap and the coolant res. cap. Start the engine and let it idle for several minutes. Stop the engine, and then check the coolant level in the radiator. If it is low, add more coolant until it reaches the top of the radiator. Check the coolant level of res. and if low fill to max. Start engine and check for leaks.
WOW, a lot of typing.
Old May 2, 2005 | 11:34 PM
richardsb's Avatar
Default coolant
Thanks for the help? It is well appreciated.
1ArmBandit
55
Oct 14, 2015 09:03 PM
essonlaker
Sep 10, 2015 01:12 PM
Randy Lee Frye Sr.
Sep 9, 2015 02:30 PM
Kenidah
Sep 7, 2015 07:50 PM
