banshee ?
A friend of mine is putting T5s on his banshee,he has k-n.What is a good place to start
on jetting?I am in Mi,i think it is sea level for elevation.I did the search and for some reason
its not working.Any help would be great.
If you are at sea level and the weather is still real cool, then start with about a 310-320. Make sure to double check on the altitude. If you get above say 500-700 feet then drop down to about a 290-300. You might also consider raising the needle one notch (lower the clip) until you can check jetting. I know the stock setup is kind of a pain, but always better safe than sorry. We end up with around a 280 in warmer weather and we're about 850 feet above here. Bubba
Jul 7, 2015 11:00 PM
